I installed a set into my ARB bar on the 120, so I assume they are similar. Mine came with a double ended plug for install directly into the rear of one of the headlights. The previous headlight plug adjoins the rear of the Stedi plug. Along with a switch line and a power line via the fuse/relay, it all works when high beam is on. I have not bothered with the 'Daytime running light' function currently though.
2008 GXL D4D, Silver Ash, ARB Deluxe Bar, T11 Domin8r 12000lb Winch, Factory Towbar, ARB OME Lift, Safari Snorkel, BFG AT/R's, Redback Dual battery with Redarc, GME TX3340 UHF, Lighforce HID XGT 240s, Rhino Aero rack, ARB Awning, Custom drawers, MSA Drop down fridge slide, AMTS tyre Spacer with twin LED work lights.
From memory, i cut the plug off and soldered those 2 wires to the new fog light, which leaves a spare wire from the fog light. Then i wired this into the fuse box into 12v ignition so the DRL is illuminated when the car is running. Can't remember the colour wires unfortunately.
