Hello everyone, I have a vx and I would like to put the radius of the kakadu, and to disarm the 2 vehicles but the electric branch is different, does anyone know if the branch has any pre-connection or if it is different
Replace vx stereo
Hi,
I have been doing a bit of research and came across this forum. It looks like the Altitude and the VX models are tricky (if not impossible to get a stereo upgrade). I have a 2012 Altitude and have been looking at ways to upgrade the stereo so that I can use Android Auto / Apple Car Play.
After a few months of research - it appears this is very hard to do due to the factory Sat Nav unit (which also controls the back row entertainment / drop down screen).
The fascia alone costs more than the head unit and installation, and it comes with certain issues like losing control of certain features like the front and back sensors appearing in the main screen
See: https://stingeraustralia.com.au/product/jptoy06/
I found a video on Youtube on how it might be done as a second screen -
https://www.youtube.com/watch?v=f5CUpcBoQ24
The issue with that particular use case is that you always have to look down, so if you use Google Maps etc,
I was looking at the Alpine Halo9, and some Kenwood wide screen units which fits nicely into the 200 mm space where the existing DVD player is installed. Those units appears to have a pop-out screen so you can actually angle it higher so hopefully it sits over the air-cond control.
Does anyone (owner or installer) have any experience in this type of install? Anything to look out for / I have missed?
I think the end result is a new head unit, connected to the AMP, while leaving the factory screen for the camera, sensor displays and control of the rear entertainment unit (which will have to rely on the headphone out in the back seat).
$113 facia kit
https://www.digoptions.com.au/facia-...l-toyota-prado
They may be able to help with a replacement unit as well.
For those of you who are still looking for a solution for the Altitude Model - in late 2020, a portal Android Auto / Apple Car Play compatible unit was released.
It is called a Coral Vision Portable 7" LCD Touch Screen.
Mine arrived this week and it is pretty good. I couldn't use the mounting that came with the unit because the screen is quite large and can obstruct your view in the front windscreen, so the alternative was a DVD-Mount bracket and attached to it. Screen now sits just above the factor DVD unit in front of the air cond control panel.
So far so good, very responsive, and works well with audio etc via the standard AUX in.
Detais:
https://www.amazon.com.au/Coral-Visi...2853059&sr=8-2
Hi all
Im having the same issues trying to upgrade my stereo in a 2012 prado altitude. I found this and is meant to work with all OEM setup
https://fb.watch/exUji9tubT/
does any one have this setup from GPS made to fit?? Thanks
