Hello everyone, I have problems with my grj150, at any moment of the journey the stability control turns on and the car brakes me without any reason for a strong curve, I checked all the abs sensors with the techstream and they are fine, the point angle zero and g are reset with standard toyota procedure, anyone have an idea?
Stability control problem
Hello everyone, I have problems with my grj150, at any moment of the journey the stability control turns on and the car brakes me without any reason for a strong curve, I checked all the abs sensors with the techstream and they are fine, the point angle zero and g are reset with standard toyota procedure, anyone have an idea?Tags: None
Originally posted by Bear63 View PostCheck your tyre pressures , known to do this if they are overinflated for the conditions, especially on curves
The tires have 30 psi.
the problem only occurs in curves when turning to the left, in the toyota they have not been able to solve the problem, someone has ideas, I need your help
