Originally posted by tempestv8
View Post
Help with D4D intermittent stutter/ miss
Mine had the low and high speed stutter . I showed them the Tojo Tech Bulletin that I got from PP so they reflashed the ECU and the transmission and it seems ok now . It seems to change down more readily at highway speeds when going up hills I've noticed . Haven't noticed the typical flat spot when coming out of a roundabout which is good .
Cheers Ross
Hey Matt, do you have an tech news flashes about changing the injector seals? Booked mine in for 90k service and questioned about if these were replaced during the 80k service as a part of the service. I was informed that they only do physical check (and remove the injectors) if there is a lot of tappet noise. I told them to do it at next service but not happy that they don't do it unless you ask.Stephen Bloomer
Lane Toyota Melbourne are lying asshats. My 20k service. They claimed they checked this and I was on 0300.it's on the service report.
Today at a different dealer. I had the firmware upgrade installed. See proof.
New dealer also replaced clunky tail shaft. Lane told me no issue.
Avoid lane Toyota. I'm going to make a formal complaint tomorrow to head office. Little that will do.Last edited by Vk3bq; 27-10-2013, 11:53 AM.
Stupid iPhone posted the same sheet 3 times.
In June. Lane Toyota (on their service report) confirmed I had latest software. 0300 (not photographed. But I will)
In October. At a different dealer. They had to install 0300. From delivered 0100. As per that photo.
Clearly lane Toyota are lying asshats. Avoid that place.
