The title says it all really. We got caught in a storm on a dirt track which left the vehicle covered in mud including the engine after a few mud holes. I would like to hear how other members deal with mud covered engines to prevent damage to sensitive parts?
Is it OK to use a pressure washer on the 150 diesel engine?
Should be fine as long as you don't use fire water wash the engine,its a highly flammable liquid.Fitted so far:-Toyota Alloy bar,Redarc BDCD1220 battery managment system and dual power outlet,tracklander full length rack and ladder,Milford cargo barrier,Kaon transmission guard, UVP& Lower Shock mount Guards,Dobinson/Bilstein suspension,Toyota Bonnet and headlight guards,39ltr engel and an opposite lock stubby holder (from the old '80' series),Polyair Airbags,Pradopoint sticker,Gonefishin' custom Sidesteps.
Every time we do day trips, some love diving Into the mud, then they go home & wash it down. Never heard of any problems on 1kd prados.
Most services I wash down engine bay afterwards.
Every injector job gets thoroughly washed the day before the big job. They also get a rinse after.
I have never had any trouble with it. I do blow them dry & then drive them.
I use kenco heavy duty degreaser, available at Bunnings 5lt $14.40.
Also truck wash or super wash.
Mixed in a 2 ltr spray bottle. Spray & soak for a few minutes, re spray.
Use pressure on on solid materials.
Use distance caution when directing near electronic devices like abs module, maf sensor for 2 examples.
I have hit them pretty well & never had an issue, but still usually use caution.
Better to find out at home or workshop rather than in a river crossing if there is a miss sealed item.
IMO this happens occasionally on other brands, which I don't work on anymore :-)
Prados are the go! What a vehicle, what a community.
Originally posted by Puddock View Post
I have some more.......
1.)
Don't use that flammable spray degreaser in your engine bay. Use it for dissolving grease parts washing only.
Or
Have a fire extinguisher handy.
2.)
Only use water based degreaser on your vehicle.
As I said I use & reccomended the kenco.
http://www.bunnings.com.au/kenco-5l-...easer_p6101169
Don't get ripped off at supernotcheap, watch them! They will screw you!
http://www.supercheapauto.com.au/onl...ecommendations
3.)
Don't run the engine, the degreaser & water will work its way in to bearings like drive belt idlers & dry them up.
I have been fastidiously washing/cleaning engine bays after services for 24 years.
Thank you for reading.
Thanks Guys
For a start I would not use a degreaser on mud - plain water is enough. I just wanted to know if there are particular parts to avoid with a pressure washer other then the obvious ones.
As to degreasers, there are two types, caustic soda based (sodium hydroxide) and that based on hydro carbons. The first is cheap and nasty particularly on paint work and aluminum alloys - the first is more expensive but more effective. If some members are using pressure washers without issues then I should be OK.
Originally posted by Corigator View PostI checked out that degreaser from Bunnings. From the ingredients, you would do just as well using diluted dishwashing powder.
First look up the old flick "the toxic avenger", haha, just kidding no don't do it, even diluted it can eat away alloys, I'm not sure what sort of a chemist you are but don't rely on your own chemistry calculations lol......
Needs to be carefully diluted
Originally posted by Anth120playdo View PostI'm not sure what sort of a chemist you are but don't rely on your own chemistry calculations lol......
and yes I know that the dishwasher powders are caustic based; not quite like Palmolive. But soak in it if you like.
OK just in-case anyone takes me seriously Caustic Soda will dissolve your skin and cause nasty burns.Last edited by Corigator; 15-04-2016, 02:52 PM.Greg - 08 D4D Prado,
Originally posted by Corigator View Post#### - If I get my chemistry calculations wrong people die
I'm no chemist, don't know what's in the kenco, but even well diluted its very effective in dissolving grease, including egr soot.
Best thing I've used in my time. I'm surprised it's on the shelf. Bit like the bifentherin or whatever, you know the one I mean, very exe.
