Squealing from engine bay - coasting and under load (intermittent)
  • #46
    Kaukapakapa,
    No I didn't try putting it in neutral, didn't think there was any point. Squeal already stopped at times just lighten the foot of the accelerator and coasting, so yes it can be load sensitive. But suspension work affected it too. Hence thought it was a loose bearing changing the orientation of brake rotor to caliper, but load related micro movements with healthy bearings may already be enough. Couldn't really force it to come on, it would just start at some stage during a drive, for short moments initially, then get more constant as drive continued. But I had it also squealing right down to a stop and pitch did not change, that is what it makes me think its resonance, pitch purely determined by the mass of the vibrating body. It did do it also when towing a caravan of 2.3t, symptoms exactly the same, but caravan brake controller is inertia sensing and brake rate is adjusted to match that of the Prado. Very hard to locate by listening, comes sort off from everywhere, sound probably reflected and bounced around off the road, and may be not just one brake doing it, assuming that is the actual cause. Hence also not being able to demo it to anyone, more or less guessing and checking possible causes one after another. Depends really when your squeals started, mine in both cases with pads around half worn. I do a lot of suburbia driving during the week, mostly prefer driving in S so and pushing down on stops, so half worn is roughly at 40000km. If one did a lot highway cruising it would take longer and also would be longer to get through the squealy period due to reduced brake wear. A trailer of your stated weight would be braked and hence with brakes adjusted with matching brake rate to Prado would hence not affect brake wear rate.
    • #47
      Originally posted by Greasemonkey View Post
      I'm now speculating that it is perhaps a resonance situation with half worn brake pads, just having the right mass at that wear level. Now that they are light in my case they perhaps don't resonate anymore, just like is the case when they are too heavy when new, just off tune. I haven't got an opportunity to check third time round for a while as a will wear those pads out till they actually need replacing. My experience might not apply to your situation but may be worth a thought, check and discussion.
      Hmmm. I might just look into this a bit more. Once I had the suspension lifted it, the noise went away for months but this might be another avenue to look at ...Thanks
      • #48
        Quite interesting reading this. I’ve got a 2013 D4D (non dpf) making a similar noise for 2 years now and we’ve narrowed it down and isolated it to an exhaust coupling under the drivers seat area. It’s a weird coupling with two spring and bolts, same as been posted up here already.
        Typically, Toyota view the exhaust as wear and tear so not covered under warranty.
        The cost of the replacement coupling is $150 less than a complete new stainless steel exhaust which I’ll be fitting in a month or so. Will see if that fixes the issue.
        2013 150 Prado Altitude D4D in Graphite - [B][URL="http://www.pradopoint.com/showthread.php?37048-Brougham-s-150-Altitude-build"]My Rig Build thread[/URL][/B]
        • #49
          I hadn't been on Pradopoint for a while. I wonder how you went with this?
          • #50
            I heard this noise from my 2018 GXL Prado for the first time this week. Done approx 38,000km. Seems similar to many others. Only makes the sound between 45 & 70km/hr. Only makes the noise when the accelerator is pressed. Stops when coasting. Sounds like a rock caught in the brake caliper but doesnt change pitch when brake pressed. Pitch doesnt change with speed. Slight pitch change when suspension travels due to normal dips in the road but doesnt change if you ride up the edge of a traffic island while driving or swerving side to side. Nothing visually obvious underneath but I hadnt thought about checking exhaust seals. It didnt sound exhaust related but will keep an ear out for it. It made the sound for about 20km one night but hasnt made it since.
            • #51
              wow, I’ve been awol as well.
              replaced the exhaust with a new 3” stainless system and noise has completely gone.
              • #52
                I picked up a used 2012 last Thursday and the squeal started after about 70km so straight back to the Toyota dealer who advised it would be the exhaust flange and said they’d fix it under warranty. Dropped the car off this morning and got a full service done at the same time so I knew everything would be running as it should be. 15km from the dealer and the squeal came back. If the answer is a new exhaust I’ll turn the radio up and live with it for a while but I’m staggered how common a problem this is.
                • #53
                  Jumping into this thread as it seems I have the same issue. 2015 Prado Kakadu, pretty much stock aside from a Safari Snorkle. No lift or suspension mods.
                  It is not a suspension squeak, it sounds almost like a dry bearing. It doesn't start until I have been driving for half an hour, quicker on hot days. It remains consistent no matter what revs the engine is on, it doesn't seem to change under cornering. I am fairly happy it is not coming from the drive train. I can't replicate it by revving the engine when stationary.
                  The exhaust issues make some sense it is clearly coming on as the car heats up. Local garage tightened the flexible joints but the noise is still there.
                  • #54
                    Had the squealing noise issue last year and mentioned it to my service mechanics (TLC in O'Connor). Said it was a common problem and was the centre exhaust flange. Easy repair with modified springs and a new exhaust gasket fitted at my next service. Haven't heard it since.
                    • #55
                      I had the centre exhaust gasket replaced yesterday and seems to have stopped the squeal.
                      • #56
                        Hi Guys,
                        just wondering if since replacing the exhaust gasket/springs the noise is now home? I’ve got a 2018 GXL doing exact same thing.
                        thanks
                        • #57
                          Over 12 months down the track and still no more squealing (if you don't count the kids whingeing occasionally)
                          • #58
                            Had same issue in my (2017) and my mates (2019) prados. Mates prado we thought it was a dragging caliper or park brake but turn out to be a dry propshaft. I had mine serviced and my shaft greased 2 days ago, currently hasn't come back.
                            • #59
                              Hi mate I went down to toyota and they didn’t know what these modified springs are I had the gasket replaced but still noisy
                              • #60
                                These were something the guys at TLC in O'Connor (Perth) modified themselves. They said to me that they installed longer bolts and modified the springs as they were getting a lot of customers with 150 Prado's having the same issue.
