Hi guys, sorry in advance for the massive life story but any help would be appreciated, and I've got a 2011 gx prado manual diesel. Cheers.
I have this slight problem where the car doesn't want to start, I went out to glasshouse on sunday and got stuck and for about 5 minutes the alternator was sitting in the muddy water. After i was pulled out, the battery light came on, I spray some inox on all the termials and tried to get to the alternator.
Hoping it was just the alternator getting flooded and it would dry, i drove like normal noticing that when i was in high revs (about 2500 - 3000) the light would go out.
About an hour later we start pumping our tires up and head home, while the compressor was going I heard that it was slowly dieing, so i quickly turn the compressor off as it almost stalled my car.
We got the multimeter out and checked the voltage, i had about 6 volts at that time in the battery, so I reved the car to see if it started charging but nothing at all. Then the car choked and stalled, got a jump start and made it about 100m before the tacho went dead and the accelerator did nothing.
Got it towed home and i cleaned everything out (focusing on the alternator) and charged the battery over night. Woke up this morning and the starter motor doesn'teven want to try, I hear the tick from the starter but after that nothing, the light that come up on the dash are an orange engine light, oil light, hand brake light even though its not on, and the battery light.
If any you you guys could point me in the right direction that would be appreciated thanks. Dale.
