Fuel fuel warning light flashing after changing fuel pump
  • Fuel fuel warning light flashing after changing fuel pump
    Model is 2010 kakadu
    so I am in the process of doing the 150k service
    i dropped the fuel tank out and replaced the pump
    all was fine prior to doing swap
    I have pulled it back out and bench tested it all seems to be ok
    all hoses are on in correct locations
    dash displays check fuel system and warning light (!) on solid and fuel warming light flashing
    pulling my hair out please help guys
    Got it sorted thanks for the help guys
      what did you find?
        Just removed battery for 1/2 hour and came all hood
        no idea what done it
          By removing/disconnecting the battery you likely would have 'reset' some offending code in the ECU.
