Ambient Temp Guage
  • Ambient Temp Guage
    Hi, can anyone help. On hot days my 2013 Kakadu diesel gauge for the outdoor temp reflect far less than the actual temp. For example on a 28 degree day it will show as 15. In cold weather it is no problem. Apart from the annoyance with the incorrect reading does this affect the engine performance in any way. Is it used for engine settings at all? Thanks folks
    Faulty sensor. Try replacing it and see if any change. Located behind front grille.
      Intake Air Temp Sensor is an input to the Engine Control ECM.
        He is talking about the sensor that controls the dash display for outside temperature. It has no connection to ECM or engine parameters (tune, etc).
          Thank you, I will try to locate the sensor and work backwards from there.
