150 rear drawers
  • 150 rear drawers
    I had an email from UV 4x4 in Brisbane tonight stating that they had drawers for a 150, indicated that if you had 120 draws then they will fit with a different mounting kit.
    [b]Rob[/b]
    Re: 150 rear drawers
    I did not want to remove the seats as the space gained v/s the work to try get a decent finish on the trim and floor did not seem worth it.
    I made some enquiries for a wedge design drawer system to level the floor out but was quoted $1400.00 + freight and decided to make my own. Cost $400.00
    The weight of the drawers, fridge and recovery gear has also leveled out the suspension nicely.
    Here are the photo's, I am just waiting on the stainless steel latches to arrive so I can finish them off.
    Prado 150 GXL - V6 Auto, ABR-SIDEWINDER Dual battery System, Tekonsha P3, 50mm Lift kit - King Springs & Bilstein Shocks, Polyair Bags, BFG 275/65R17 Tyres, Milford Cargo Barrier, ERPS Extreme use 10 coupler rust protection, Rhino Rack, Factory Towbar, ABR-SIDEWINDER fridge/freezer, ABR-SIDEWINDER compressor and PSV deflators, Twin Drawer system, Fridge Slide, Twin 23L water tanks, 80W Solar Panel, Hot Water Shower, ARB Awning, Toyota Seat Covers, ARB Winch Bar, Warn XD9000, HID's, Snorkel .
    My website: [url]http://www.sidewinder.com.au/[/url]
      Nice work although it makes the fridge pretty high to reach into
        That is why next time you buy one of the drop down ones...you can always change it out. I am sure he used what he had around from the last one.
        Manata 3" Exhaust, Blisten shocks, King Springs 50 mm lift, Poly Air Bags, Roof Rack, Iron Man Bull Bar, HID 50W LightForce XGT spotties, Daul Batteries, GME TX3440 & AE4705 ant, Upgraded window washer, Bonnet Scoop, Tunit chip, bonnet protector, headlight protector, Cooper STT's, ScangaugeII, Dash Mat, Endless Air, Stebel Nautilus, Diff Breathers, Water Sedimentor. ([b]Camprite TL8s [/b] Arrived ALIVE~!)
          It is about the same height it was in my 100 series (neck high) ;-)
            Yes it is my old slide, strong as. I will look at the drop slides at the next show.
              Great job ABR Sidewinder. Just wondering how you secured the draws on top of the rear seats.
              2009 GXL Prado 150 - Silver Pearl Turbo Diesel Auto........ with a wish list as long as your arm!
                I removed the 4 tie down points and made spacer bushes to the same height as the carpet, then bolted down into the same holes again with HT bolts and large washers. The drawer system is then bolted to the cargo barrier and the barrier is bolted down to the floor.
                  I decided I would use a shelf to regain the 120mm lost to the seats.
                  Found the most cost effective solution to be IKEA $70.00 8)
                  This now gives me space for chairs and other light gear, the frame is 30x20 square tube and the shelf is weld-mesh. I finished off the front with 17mm ply covered in carpet.
                    ABR Sidewinder, I see you have Rhino Racks attached to the factory rails. Do you know if they are the same racks from the 120 Series. I have got a set of the sportz racks (i.e. the aerodynamic version) that fit to the factory rails on my 120 and was going to put them on the new vehicle in March (if they fit). The feet for my rack clamp to the rails and don't fit into the groove along the inside of the rail. I have read that the distance between the rails is slightly bigger on the newer model so it may be that I can use the same feet but get new rack bars. Thanks.
                      Yes same kit fits both the 120 and 150 series.
                      My 150 series is 100cm between the rails.
                      Regards
                      Derek
                        My latches arrived today and now fitted and working well.
                          To free up some space in the drawers I decided to use the small space on the side of the fridge to mount the air compressor.
                          It is now easy to use and I just keep the air hose in the drawer.
                            Hi everyone
                            This is my my first post and I didn't want to come to the party empty handed. I have been reading this forum for quite a few months now waiting for my 150 GXL to arrive. I picked it up last Tuesday after waiting since December. I have always been involved with modified street machines and this is my first real time modifing 4x4's and first time on any forums (so sorry if my forum etiquette isn't right). Found this though and had to be part of it!!! I had a old series 3 landy years ago I took over Moreton Island a few times a year and loved every minute of it. Its good to be able to get back into it again.
                            I have spent the last few weeks building these draws to fit in the back. As you can see I have removed the rear seats to get max height in the back. The whole thing is bent up from 1.6mm zinc plate and running on bearings then carpeted all over. Yes I'm aware that one of the drawers the carpet seems a differnt shade!!!! I glued the carpet on upside down so the grain was running the oppisite direction and now looks different. I am thinking of pulling it off and redoing it. I have heaps more photos and the sheetmetal cutting list if anyone is interested.
                            I'm pretty happy with it so far but only the beginning for this prado as we have already planned a trip to the cape in June.
                            Once again, loving this site!!!
                            [color=#4000FF]2010 GXL, ARB BAR, GOODYEAR MTR'S ON STEEL RIMS, CUSTOM REAR DRAWERS, DUAL BATTERIES, CARGO BARRIER, GME UHF, RHINO ROOF RACK, ROCK SLIDERS, AIRTEC SNORKEL, DUAL DROP FRIDGE SLIDES[/color]
                              lissted,
                              Those drawers look very professional. You've done a fantastic job.
                              Was wondering if you had a better pic of the whole rear cargo area from top to bottom, just to see how much room you have in the back.
                              I've been waiting to see how rear drawers would look with the rear seats removed and no plastic trim across the bottom of the cargo area.
                              Do you have any plans to cover up the left and right bottom corners where the trim would clip in?
                              Keep the 150 mods coming.
                              Stewy
                              sex vidio
                              replica watches
                              parisbahis
                              holiganbet
