Just wanted to share something I discovered on the weekend - it is very easy to remove the plastic shroud that prevents you seeing the towbar in the reversing camera.
1. Remove the spare wheel cover
2. Remove the camera bracket. To do this involves undoing two bolts - One above the camera and one below the camera (they are very obvious). Then reach behind the camera and unplug the camera.
3. Remove the shroud. Now you should have the camera and supporting bracket in your hand. Turn it over and you will see the shroud is held in by two small phillips head screws. Remove these screws and the shroud will come away.
4. Put everything (except the shroud) back the way you found it.
5. Reverse up to your trailer
Because the camera is not centred on the vehicle it is surprisingly hard to reverse up to your trailer accurately, but nevertheless, have fun trying!
Pawky
Pawky
