Do you know if the intervolt dcdc pro charger also acts as an isolator...so I can draw power from my aux battery only ? The product sheet isn't clear and they are closed over the Xmas so I can't call them. Cheers
Intevolt dcdc pro
From a quick look at the manual if you have set up in ignition control mode the main and auxiliary are isolated when the ignition is off. I suspect the same in other modes but that is not expressly stated.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
- 1 like
Generally all DCDC chargers designed for dual battery systems are isolators.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
- 1 like
