Who has upgraded their Tyres on a VX or Kakadu?
  • Hilux sr5 are et30 I believe
    [LEFT]Silver 150 Facelift
    • Originally posted by AussieAndy View Post
      Yep, which means they aren't recommended - i.e. they will foul the KDSS component and is illegal on the 150 as it narrows the track.
      amts
      Ninja Poster.
      • Originally posted by fido666 View Post
        After spending a week in the Vic High Country I can appreciate the benefit of some extra sidewall although there were a couple of staked tyres amongst the 17 owners. The D697s in the 265/60/R18 really bag out when dropping the pressures, had others thinking the pressures were too low. Might get something else next time, the D697s are looking a bit thrashed after the GTG.
        Fido, interesting feedback. What would you get next?
        2013 Kakadu, pearl white, Cooper ST MAXX 275 65 18 123Q tyres, Safari Snorkel, ARB UVP, diff breathers, UHF GME TX3345, Red Arc 2nd battery, BMW luggage hdp, tint, ARB bull bar, synthetic winch, OME 2" lift, LED Intensity spot lights, ARB side steps, Kaymar rear bumper with 2 JC, spare and LED pole ligh, ARB compressor, ARB front air locker, Toyota rear diff lock.
        • Originally posted by Bawky View Post
          Not sure, it's a quandary. I'm happy with the D697 LTs on road but now there made in Indonesia I'm not convinced they will have the same longevity as the D694s I had on my 95 series which were made in Japan. I keep getting told to get BFGs but they don't seem to handle so well on wet roads in my limited experience using them.
          • Hi Fido,
            Do you think the issue is the lack of sidewall height which causes the side walls to bulge with lower pressures? Would a higher sidewall bulge less on lower pressures?
            • I really couldn't tell you Bawky as these D697s are the 1st tyres we've ever dropped the pressures on, the previous 95 series didn't see any real action. I should clarify that the pressures were lowered to 18-20 PSI for some tracks and they normally run at 40 PSI, that's a big drop.
                Can you tell me what the standard 18"Kakadu rim's offset is?
                Am I correct in thinking that a et15 sits 15mm further away from the chassis than a et30?
                  et25
                  Yes
                  • Thanks amts.
                    I am thinking that sticking with the 18 inch rims might be the easier option.
                    1. If I wanted to have the same offset and have a 17 inch rim which is compatible without rubbing and fit over the brakes what would the choice be?
                    2. Are steel Toyota rims 17 x 7.5 ET25 and are they compatible?
                      Thanks amts.
                      No they won't fit over the brake. U'll need to go back to around a +10.
                      All the info u need is back further in the thread
                      2010 Kakadu T/D, Auto, Sahara bar, HID IPF 900s, Beaudesert Exhaust. 2' Bilstein lift, Steinbauer chip, rally X mudflaps, kaymar rear door getup, Cooper AT3 275 65 18 on KMC wheels and bfg km2 285 70 17 on dick cepek torque, safari snorkel, ARB roof rack, dual batts, uhf and brake controller and a bit of other crap.
                        Thanks amts.
                        The problem with ET25 17" wheels is clearance around the KDSS. A few people have put ET15 17" wheels ok and FJ 17" wheels which are ET 20 from memory. The factory steel wheels are ET 30 and won't fit and would be illegal anyway due to reducing the track.
                        • Decision Made
                          Due to the NSW RMS feedback and changes last November I have purchased 6 Kakadu 18 inch rims as a second set and purchased the new size 275 65 18 Cooper ST MAXX LT tyres 123Q. They don't rub anywhere on first fitting and I believe they are legal from my enquires.
ID:	648163 Click image for larger version
                          • Looks good and diameter is legal.
                            I'm surprised that the 818 mm diameter don't rub on the mudflap, if you turn the wheel. Mine (about 808) rub under light breaking when the wheel is turned to the right.
                            [ATTACH=CONFIG]16029[/ATTACH] [ATTACH=CONFIG]16030[/ATTACH]
                            2010 Kakadu. TJM T13 bar, TJM 9500lb winch, FJ Cruiser 17" rims with 265/70R17 Coopers S/T maxx, 40mm lift, Dobinson's C59-726, Bilstein shocks, Airtek snorkel, Recovery points, Brown Davies bash plates, TG150 transfer case guard. Rhino Pioneer Platform SuperPeg Rear Awning. Drifta Drawer System, Cargobarrier. Optima dual battery. GME UHF, Sandgrabbas.. ARB 47l fridge freezer.
                              Those rims must have cost a fair bit. Or did you get them from a wrecker? Tyres look good!
                              • Hi Fido, thanks for your help with the tyre decision. It is appreciated. I was able to pick up 6 rims for $2,250 from a person that deals a little in them. I figure eventually I could sell them although it may take a while. I like the 2nd set as it allows for a road set and if we are happy with the ST Maxx all the time then we can use the worn ones around town and use new or the ones with plenty of tread for off road use. I have been told don't go on big trips with less than 50% tread. This allows us to run them down separately.
                                The Yoka's are great around town and actually not bad off road. We are going to some large sharp rocks, so the LT construction and tread depth should help (I hope).
