I bought some of the "Titan" drawers from the "4WD Supacentre" in Lilydale today. Looking at them in a friends car they looked great and he said he was happy with them. He did say he was a little disappointed in 4WD Supacentre because they said the 120 ones would fit the 90 series (they don't sell 90 series as such.) He found that the wings that go with them required cutting quite alot ofthe plastic trim on the passenger side and left a big gap on the drivers side.
I was told the drawers fit the 90 series and you can use a universal wing kit to make up the wings, they do fit, but in order to get them to fit you have to cut the base of the plastic wheel arch trims both sides. Then the drawers fit up against the actual wheel arches with maybe 1mm to spare either side. Next problem is they don't sit flat, well in my car at least so I'll have to make up spacers, including one at the front. If you use the existing third row seat lock in points to bolt into the support isn't really wide enough, so I'll have to devise a spacer, maybe a 10mm thick piece of wood to sit under the front.
I'm not saying they're no good, especially at this early stage when I haven't fully fitted them. Just giving an idea of what to expect if you get them. They are very heavy IMO unnecessarily heavy. The edges on the steel are very sharp- I actually filed them down before getting into it to avoid cuts. And they were marked and scratched when I got them. Theres a screw sticking out of the front of one of the drawers for no apparent reason, the supplied bolts are a different size from those used to fasten the seat latches down so will need to get some longer ones of the right size tomorrow. They do fit but expect a fair bit of stuffing around if you get them.
