the only way you will be able to paint over chrome is if you remove it first. The only way I know is by using a sand blaster as the paint will not stick to the chrome. Then its just a matter of priming then painting the item the colour of choice. The sand blasting is best by the professionals as its a bit of a messy affair, unless you already have the equipment,
Zook.
97 Vitara 1.6 JX Day Tripper(550klms range), 98 Prado V6 LPG GXL for Touring (1400klms range), Offroad Cub Camper for Overnight.
Another alternative is to scuff the surface, fine sandpaper or brillo pad and then use a quality etch primer and follow the paint system through prime and top coats. I have done this successfully in the past.
Yer thanks for the advice guys. As I don't have any access to sandblasting and I reckon it's cheaper if I do it myself, also I don't after that top look just wanna get rid of the chrome.
mjrandom do I have to totally scuffed off the chrome till bare metal exposed?
No need to remove the chrome plating unless it is peeling. Just rough it up a bit to give a key for the etch to grip onto and then the primer (if necessary) and top coat go on. Ask at a paint shop or read the instructions on the etch primer. Easy as...
