Hi,
the bracket holding the LSPV has started to rust. I would like to remove it from the ladder frame as well as from the LSPV itself so I can clean it and paint it.
If the two bolts/nuts holding the bracket to the LSPV are removed, will brake fluid flow from the bolt holes? I just want to be ready for any eventuality.
Thanks!
Thanks!
