I've noticed that all my brake dust is settling on the front wheels.
And, the brakes don't seem to be performing as well as I think they should.
So, I suspect the rear brakes aren't doing much.
The most likely culprit is the Load Sensing Proportion Valve (LSPV).
I assume I need to adjust this to compensate for the 3 inch suspension lift, in the back.
But, how do I do that?
There's an adjustment mechanism, next to the spring.
But, it seems pretty useless, given the angles involved.
I suspect I might need to install some kind of bracket extension, in order to bring the spring higher up on the panhard rod (closer to the chassis).
Will that work? Will it make a difference? Are there any tricks to fiddling with the LSPV?
I have dual-rate OME springs with ABS.
BlueRock
BlueRock
