Loud constant hum
  • Loud constant hum
    Hello there fellow Prado people
    I have bought a 2002 3.0 TD prado and it came with a wonderful constant hum. The hum increases in pitch with speed regardless of road surface and doesn't go away in neutral or with the clutch depressed. I know thye Bridgestone AT's are out of shape and must contribute to this due to lack of rotation from the previous owner but could this also be a diff or transfer noise?
    Not sure how to find out.
    Can anyone offer some ideas?
    Thanks Dave.
    Sounds like the tyres, how many klms have they done.
    [b]Rob[/b]
      I would guess around 40-50 thousand - they still have tread (50%)but are chipped and the surface accross the flat top is not flat ie: high and low points and inside edge wear. I have had tem rotated but nochange at all.
        At around those k's my bet is the tyres, they can get noisey if not looked after.
        [b]Rob[/b]
          At what speed can you start to hear the "hum" ?
          2004 GXL V6 and loving it.
            The hum starts at around 25-30 kms and at 100 it is quite high pitched and loud. Not normal for sure. Everything else is fine - car has done 226000kms. Should I change the diff oil?
              I can also hear it almost the same on gravel if that helps?
                Must be loud if you can hear it on gravel roads.
                Does it change when going around corners or if you turn the wheel while driving from left to right?
                Does the noise change a lot when you brake?
                Does it change when you accelerate or back off?
                Its hard without hearing the noise. You might have to take a mechanic or a drive line professional for a spin and let them have a listen.
                  No its just always there increases to a higher pitch with speed regardless of road surface and stays the same even in neutral. Could this be low oil in the front diff? And how would I check this?
                    If you remove the filler plugs on the diffs (The highest of the 2 plugs on the diff) the level should be level with the bottom part of the plug hole. Sometimes its higher and some will come out when you remove the plug especially if diffs are warm so probably best to check cold.
                      If I have to drain and fill it what oil is used? Is it just Gearbox oil ? Sorry I'm not that mechanical but I manage to get by with the right advise.
                      Thanks again
                        This is what i would use...
                        CASTROL LSX 90 for rear holds aprox. 2.6 Litres
                        CASTROL EPX 80W/90 for front holds aprox. 1.1 Litres
                        Others would use other brands but this is what I would use.
                          thanks I will give it a go and let you all know if it makes a difference..
                            chuck the missus and kids outa the car see if that fixes it
                              Hi Fellas. Driveshaft u-joints or out of balance drives shafts will give similar symptoms. cheers.
                              2005 100 Series Landcruiser. 4.2 T/D 5 speed auto. LTD c/w AHC/Leather etc.
