90 Series Front Axle Bushes
  • 90 Series Front Axle Bushes
    Has anyone replaced the front axle bushes in a 90 series? Can the front mounting bushes be replaced or do you have to replace the mounting brackets and bushes as one unit? What about the rear bush/mount? If the bushes can be replaced do you need a 10/20t hydraulic press for this or can they be done some other way?
    Bushtreka
    Prado 150D (2017) & Prado 90 V6 3.4L (1997)
    If you're referring to the front upper and lower control arm bushes then yes they can be replaced. Toyota, nolathene, super pro etc all do replacements. You'll probably need a press. I've seen YT vids of people using jacks etc but I just took the arms and the new bush kit to the shop and they put them in for me.
    The rears you can do yourself without a press.
    Prado 95, not quite original!
      Anyone? I could not find the Front differential mounting brackets so I replaced the just bushing with a generic one..
      Until I come across another solution.
        Front upper and lower control arm bushes are a replaceable item.
        i think the diff rubber mounts come as an assembly, bush with mount bracket as a unit.
