I'm looking to install a 2nd battery in my 96 Prado TX and was going to buy an isolator that has this description: "Use with alternators that do not have integral electronic voltage regulator" . Does anyone know whether the Prado alternator has an electronic regulator or not?
Battery isolator
Got a multi-meter? Check yourself.
With engine running, what is the battery voltage?
With engine running (and warm after a trip) what is the voltage?[SIZE=1]2010 150 GXL Ebony Diesel | ARB Delux Bar | ARB Bashplates | GME 3450 UHF | Bilstein/Dobinson lift | SA LED Lighting 185W Spotties | Bridgestone D697LT | Wet Seat covers | LeighW's Voltage booster | Tin75 Pet barrier | 3D Mats'n'boot protector | Onboard ARB CKMA12 Compressor | Rhino Pioneer Platform | Roadsafe Recovery Points | Airtec Snorkel[/SIZE]
I've got the V6 version and have a dual batt system. But I got sick of the limited space in the engine bay for a decent sized deep cycle so built a battery box to power my camp site. The batt box has a 1 x 50amp Anderson, 2 x cig lighter sockets, 1 x merit plug and 2 x USB ports, press & hold voltage readout to know how discharged the battery is at any time. All fused. I also have a 150w pure sine wave inverter to hook up with the alligator clamps if need be too. The same amount of charging options as the $500 units. Mine cost $50 to make. I like the idea of leaving the battery box and 12v fridge in the shade of the camp site. Hook the solar panels up to it... All set. I have 2 @ interchangeable options for the last meter of solar panel cable. I can swap it over to have an Anderson plug on the end or large alligator clamps.Last edited by Brett1979; 10-01-2018, 12:02 AM.2005 120 series V6 Grande, 2 inch susp lift (King/EFS combo), 32 inch MT’s, Safari Snorkel, rear diff lock, breathers, Light Force spotlights, UHF, dual batteries.
All modern alternators have electronic regulators, you would need to go back quite a few years to find a car with non electronic type, an alternator with an old electromechanical type regulator will have a separate regulator, it will be a metal can device mounted inside the engine bay.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
Originally posted by LeighW View PostAll modern alternators have electronic regulators, you would need to go back quite a few years to find a car with non electronic type, an alternator with an old electromechanical type regulator will have a separate regulator, it will be a metal can device mounted inside the engine bay.
The only Prado in Australian that is ECU controlled is the new 2.8ltr, I suspect this would apply world wide.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
Originally posted by LeighW View PostThe only Prado in Australian that is ECU controlled is the new 2.8ltr, I suspect this would apply world wide.
Any standard VSR will do, Traxide make a very good unit, then there's Intervolt/Engerdrive/Redarc etc.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
