Hi there Im a newbie to pradopoint but get out in the bush and to remote coastal areas. Have just got my beast and it has done a venerable 550K with oits previous two owners. On purchase the stereo unit ( factory Fujitsu ten) is unable to work as it requires security re-initialisation. The procedure for re-entering the security code is contained in the owners manual which I did not receive with the vehicle. (according to previous owner it worked fine until battery replacement. I am thinking of replacing it so that should overcome the security issue, but coincidentally? after bottoming out the front suspension the odometer has ceased to display. I thought it may have been a loose connection, have disassembled the dash and removed the instrument panel and replaced it but it has not cured the fault. Could there be a dry joint somewhere as all other guages including speed function fine.
Thanks to anyone who can enlighten or assist me - particularly with the reset procedure for the fujitsu ten if anyone has manual
