Climate Control Unit/ Heater & Aircon unit
  • Climate Control Unit/ Heater & Aircon unit
    Hi all,
    Has anyone else had this issue: my climate control/heater & aircon unit has stopped working, the unit is dead. All fuses and relays have been checked and good (auto sparky confirmed). I have tried a few second hand units but these have not worked and now have run out of possible spares (Auckland area).
    Does anyone know what could the problem be, and where I can get a replacement unit - can't seem to find any others locally?
    Any help would be appreciated.
    Part no: 88650-60260. '97 Prado 90 Series (Diesel)
    I would find it strange other units would also be "dead" I would suggest the problem is not the control unit.
      I had a fault with my Climate control some years back, I traced it to a short to ground in the power supply lead to the AC compressor clutch.
      When the AC switched on the fuse would blow but I also lost dash lights at the same time, with the AC/climate control off the fuse would not blow (obviously) and the dash lights stayed on.
      Have you lost your dash lighting as well, if not have you checked power at the loom connection at the back of the control unit?
      Lee
        Hey guys, thanks for responding.
        There was an issue with a short being created by water damage somewhere inside the AC unit - needed replacing and the control unit repaired, $!000 later - but working now.
