Terminal block
  • Terminal block
    Anybody know where I can get this type of terminal block. I think the brand is "Sidewinder".
    The cap has two approx 5mm screws/nuts under it to take positive lugs which are part of my dual battery setup. When I lifted the cap, the brittle plastic broke.
    I have tried Supercheap, Jaycar and Every battery without success.
    Thanks. Frank.
    It looks like it’s the protective cover from your auto reset circuit breaker. In which case, they’re all very very similar in size (within a mm) and I often swap covers over from different ones.
    (I’m an auto electrician and deal with these on a regular basis.
      It's an elcheapo ABR Sidewinder, search the net and you'll find him.
        Thnx guys. Got it now. Did try last night but couldn't pin it down.
