Loose connector at rear of sub tank
  • Loose connector at rear of sub tank
    Hi all,
    My 90 series (model vzj95r, engine 5vzfe) used to be dual LPG / petrol fuel. I have removed the LPG cylinder, and am looking at fitting back a main tank instead. I think I've figured pretty much everything out, but there's just one 8-pin connector which is hanging loose at the rear of the sub tank which I'm confused about. It's not the main tank fuel pump connector (which connects to the top of the main tank - I've identified this one). it's not the sub tank fuel pump connector (since I've been running off the sub all this time). I had a look at a wiring diagram, but it wasn't helpful. Would anyone know what this connector is about?
    Thanks in advance for your help!
    Matt
