Indicator fuse blowing
  • Indicator fuse blowing
    My indicator fuse blew. I put a new one in which blew straight away, and so did a third, after I had checked hazards and indicators were turned off.
    yesterday I had the fascia off around the stereo so Ll of those plugs were removed and reconnected, but no wires disturbed otherwise.
    everything worked fine for the first hour or so of driving after reconnecting all disturbed plugs.
    There is no after market lights or bumper fitted.
    second battery.
    diesel model.
    Other than the hazard light switch does anyone have :
    *Suggestions where to start looking
    *a wiring diagram?.
    The short is present with ignition off.
    is not present with hazard switch unplugged
      Check everything carefully around where you were working, if you were working before the problem happened, you know where to look.
      sex vidio
      replica watches
      parisbahis
      holiganbet
