Prado 3.4 / fuel filter
  • Prado 3.4 / fuel filter
    Dear All,
    Could you please tell me where is the fuel filer position? I want to change by myself. :P
    Climb under the vehicle at the LH Front door.
    There is a plastic splash gaurd on the inside edge of the chassis rail.
    The fuel filter is mounted above that on a bracket attached to the chassis rail.
    A tip for refitting the filter is.
    *Dont do the mounting bracket up with the new filter on it until you have started the threads on the high pressure fuel lines at each end of the filter.
    They are easier to start when you can freely move the filter around.
    If you have any problems PM me and i can talk you though it.
    Ben..
    Its all in a days work for a Toyota!!
    [url="http://www.subaruclub.com.au"]www.subaruclub.com.au[/url]
      Ben..
      Many Thanks Ben! :P
      I will try to find it.
