ENGINE VIBRATION
  • ENGINE VIBRATION
    I have got a vibration or rather a hum from the engine happening at 3000 revs. any ideas?????
    engine vibration
    I also experience the same problem. Is this standard for prados?
      Standard feature of 3.4 V6 exhaust system. Can be slightly reduced by removing the main muffler bypass valve (the bolt-in thingy on the muffler front).
      Be careful not to break the bolts when removing. When refitting cover again minus the spring valve assembly, new gasket from Toyota is required.
      Upside: better pickup, gain 1 litre/100km economy, reduced exhaust resonance, low cost.
      Downside: Probable reduction in engine braking (I haven't tested this properly yet). Possible reduction in torque - seems unlikely given better performance apparent at same RPM.
      Ultimate solution: Wildcat headers, hi-flow cat, hi-flow muffler, electric exhaust-brake flap.
      - Mixtup
