Engine knocking
  • Engine knocking
    Hi everyone. I have recently purchased a 2001 3.4L Prado with about 160k on the clock. All seemed fine, has a full history, drives great, however I have now noticed a very small knocking noise when accelerating from stop. Sounds like main bearing but is quite weak and usually dissappears as I drive. Do you think that it is the main bearing or could it be anything else, such as valves? Anyone has done the change at all?
    Many thanks,
    Luke
    hi Luke do you have a video of the noise, does it make it when accelerating / under load from 20-40km/h
    2018 GXL 2.8 1GD,
      hii brissy, dont have it just yet, but im more inclining towards transfer case/diff or wheel bearings now. its quite humming knock rather than heavy knocking and does it only when under load in small speeds (cant hear that sound in higher speeds). i ruled out the valves as it doesnt do it when revving up in park.
      but could be just the sound of a used car, as it used to tow a trailer. on the other hand with the history i have with it seems like it had plenty of servicing.
      all i know is my mates prado doesnt do that sound, so im a little confused atm.
      thanks heaps but!
        Manual or auto? If manual, does this model have a dual mass flywheel?
          Should have mentioned that - its auto. Thats why i didnt think it would be transmission related.
            just tried to record a video but it is not hearable on the clip you only hear the engine. i will take it to a mechanic - guess just to be sure. but thanks guys!
