trd supercharger
  • trd supercharger
    hi iam in the process of fitting a supercharger to my v6 prado with a trd 7th injector kit and would like to know if anyone else has done this already and have had any problems will keep everyone posted on the outcome cheers rossy :?:
    99 snowy v6,bilsteins , pedders springs std height, polyair bags, bf goodrich at 265/70/16, daul batteries, safari snorkel, modified exhaust & extractors, rallie 4000s, gme tx472s uhf, 12v to rear ,40l ingel & slide ,tinted windows, rhino racks,electric brakes, trd supercharger,alpine cd & ipod, pp sticker.
    wishlist.rear drawers,,hid lights
    Re: trd supercharger
    Rossy you can be sure that there will be a few interested in the outcome.
    Not just the power change but the full sprectrum, drivability, economy etc
    Good luck and I look forward to hearing your comments
      Rossy, a good thread to gather some photo's and post a report please, to my knowledge not done before with anyone on here anyhow.
      [b]Rob[/b]
        Hey Rossy,
        I don't know anyone that has fitted one to a Prado, but I do know of a few people that have fitted them to similar models. There is a guy on A4WDA forums, coincidently named Rossi, who fitted a TRD charger to a 3.4L V6 Hilux, and another bloke Nemisis, who just fitted one to a 4Runner running the 1UZ Lexus V8(non TRD charger /w intercooler).
        Be sure to keep us posted on how you go.
        Cheers.
        2000 Toyota Prado GXL- Gone, but not forgotten...
        '92 Landcruiser HDJ80 4"lift 33's
        '91 Surf LN130 coil sas, 4.8s, 35s
        '12 Jayco Eagle Outback
          Hey guys
          Im interested in fitting a TRD supercharger to my 5vz aswell!
          I was just wanting to know how much the upgrade would cost?
          And my cars got LPG, Is it still compatable?
          cheers and good luck with the fitting. Keep us posted!
          [b]White '02 VX Petrol[/b]
          [color=#4000BF]Mods:[/color] Kicker amp and Sub, IPF 800 spotties
          [color=#FF0000]Wish list:[/color] Poly Air suspension, Pirrelli Scorpion tyres
            weput on a trd BULLET charger 2 yrs ago they set up the computer/charger for towing/economy for us gives awesome towing ability-like a mack truck and great economy when not towing drivability is much better- torque throughout the rev range no longer narrow like the stock engine . Has only the first boost pulley(6psi) so its not a bitumen melter but does have VERY long legs (200kph plus) Ours was before 7th injector but i added water injection in case of any detonation . cost -7500 plus which was cheaper than car/engine change. Ours is daily driver/touring-towing so we needed reliabilty for outback/desert travel, seems to be so far(done approx 50000) Our 2001 3.4 has from new never had a cat or oxygen sensor and needed 98 fuel or would drown itself in fuel using 91 due to high timing before charger was added , so Tom at Bullet gave us 2 programs (tunings) to run 98 or 91-problem solved.
              hey guys i have fitted supercharger but the trd 7th injector wiring would not plug into my ecu so iam getting bullet cars to fit a daul map piggy back ecu and am looking forward to putting it to the test every impressed so far but not impressed with NRMA thay wont insure the prado with the supercharger because its not produced in australia even after 26 years of insurance but shannons will. will keep everyone posted on performance and fuel consumption. cheers
                Pics woud be a good way on conveying your thread across.
                  hi guys i have the beast tuned and a daul map piggyback ecu fitted,113kw at wheels and 330nm/torque, extractors still to be fitted.every impressed. will post some pictures shortly. still to test fuel consumption but who cares? cheers and meery christmas rossy
                    Hi Rossy,
                    Congrats on a sucessful install !
                    The dyno results are excellent, more torque at the wheels than standard flywheel output and not far off in power also.
                    It will be good to see the install pics and what you think of the overall improvement in drivabilty and how the fuel economy has been affected.
                    Looking forward to your next post.
                    Lee
                      heres some photos of the finished product.towed a mates car to the summernats at canberra,car & trailer weighted 2.5 tonnes +gear.did 18.5 litres per 100ks.very happy with performance & fuel consumption.
                        It's looking good, I wouldn't mind having that power and torque available... What was the final cost for the upgrade? Any problems with install? What is consumption like without towing, highway, city?
                        98 GXL 3.4V6
                        40mm Toughdog Suspension Lift
                        265/70/16 Bridgestone D694
                        16x8 zero offset steel wheels
                          pictures look good rossi, i'd post some too if i could figure it out. hope you have a good run with the setup like we have,the grunt is awesome. don't forget to use fueldoctor occasianly though--hogleg
                            jeepster to answer your question i have not tested city/highway fuel consumption yet but it looks promissing i paided $2250.00 for the complete supergharger kit. but the 7th injecter ecu would not fit because mine is an early model parado.i had a piggyback ecu fitted & tuned by chiptorque cost $1500.00+$200.00to dyno it
                              Thanks Rossy. I have a 98, so it would probably be the same with the 7th injector as yours. The extra power and torque will be nice, but will have to wait a while.
                              98 GXL 3.4V6
