Hey guys,
I've problem with the main tank in my prado.
If the car is cold, it's running good on both tanks, but as it gets warmer, the engine studders, mainly when going uphill or overtaking (middle rev ranges).
The engine even stopped a couple of times while idling.
It seems to be getting worse as the tank is getting more empty. I can use the main tank in between and switch to the sub when it's rally bad. The sub tank is running without any problems.
Does it sound familiar to someone?
Could it be a defect fuel pump?
