hi all. I’m baffled. I replaced the thermostat and road tested no leaks no issues all good. Until the next morning after a short trip it leaking pretty bad. Got home nipped up the bolts and it stopped leaking. After a while went for short trip and it started leaking. Removed the thermostat checked everything was ok re-installed thermostat went for decent drive - no leak. Later same day went for short trip and again started leaking.
please help. It doesn’t leak after install or when hot (so it seems) only when cold I think.
