Hi everyone. I just joined this forum in the hope to find an answer to my problem and hopefully to contribute at a later stage.
My vehicle is as follows:
While driving 5 warnings lit up simultaneously on the instrument panel.
The alternator was replaced 4 months ago and is presumed operational. I suspect there must be some sort of problem with the field exciter current.
However, I don't know exactly how the voltage control circuit works on this car and I'm baffled by the 5 lights being on at the same time.
Before I day too much more. Is there anyone who has encountered this situation or similar?
Any help to shed some light on this Mostert is much appreciated.
Checked made so far.
Checked system voltage. At battery voltage at all times. No charge.
Checked all main leads, connections earth's.
All fuses. Radio fuse blown. All others OK.
Removed instrument cluster, re- seated connectors at back.
Thank you for your input.
- TOYOTA LANDCRUISER PRADO KZJ95R 3.0L 1KZ-TE SOHC 8v Turbo Diesel Inj. 4cyl 4dr Wagon 4sp Auto 4WD [03/00 - 09/02]
- Battery
- Low oil level
- T-Belt
- Water in fuel
- Unknown. Orange on the far left.
