Hi All, I have been putting up with this ticking noise for a while now, but need some advice on what it might be. When it starts ticking, more pronounced when engine is hot, by pulling on the transmission kickdown cable a little bit the noise goes away totally. I have no issue with driving the car or the kickdown of the trans. If only a bit of slack is taken off the kickdown cable noise stops, but it would be more than the cable can be adjusted, which I gather would throw the kickdown operation out. Is this a common issue, and if so is there a relatively easy fix? Thanks
Prado 1999 model 5VZFE Ticking noise related to Transmission Kickdown
