my 90 series hidden winch mount install
  • my 90 series hidden winch mount install
    I bought a hidden winch mount from J66P and installed it this weekend. The mount itself is one heavy duty piece of solid steel...
    Here is what it looks like, once installed. Note that I haven't installed the winch yet...
    A couple of comments. The mount itself is made of thick steel, all welded into one solid piece. It looks indestructible. Don't drop it on your foot, as it weighs 21 kg. It is mounted to the chassis using only 4 bolts—the ones used for the eye hooks. But, because the rails go way back, almost to the front suspension mounts, the bolts apply plenty of leverage no matter whether you push up or down. Once those bolts are torqued to spec, it's held in place by friction between the chassis and the rails, and it's not going to move. The whole setup seems much stronger than your typical winch bumper.
    So, I'm figuring this can handle extreme winch angles, without any difficulties—assuming the fairlead bolts can handle it. I jumped up and down on the winch mount (when the bumper was still off), and I couldn't feel any movement. Moreover, it looks like this can be used as a jacking point for a Hi-Lift jack.
    The winch mount sits a bit lower, and further back, than a typical winch bumper mount. This seems to put the winch more toward the vertical centre of gravity, which can have an advantage. When you typically start winching with a bumper-mounted winch, you'll notice that the front suspension gets pushed down. That's because the raised height and mounting system acts as a lever, applying downward force on the front and upward force on the back. With the lower mounting, this effect is reduced, or possibly even eliminated. That means better winching on soft ground. As for the approach angle, it seems about the same as the stock plastic bumper. It might be a bit worse if a roller fairlead is mounted—I'll let you know.
    Installation does require some work, but nothing too difficult. The main challenges I ran into were:
    1. Grinding down the tabs on the front chassis mounting. I ground the two inner tabs, and then cut the two bottom tabs, using an angle grinder. I wanted to make sure the bottom tabs didn't come into contact, so I shaved off an extra millimetre or two...
    2. Trimming the bumper. I tinkered quite a bit to see if I could leave some extra material on the bottom. But, it seems this is not possible unless I was to cut some kind of zig-zag pattern and install lower mount extensions. So, I just cut it in the same way that J66P did. That left me with two of the four lower bolt mounts, which is still pretty reasonable.
    3. Skid plate. When I first tried to fit the winch mount, I discovered that it couldn't fit past the skid place, which was about 1 cm too wide. So, I had to remove it (both plates), and do a little bit of bending with a wrench and hammer. No big deal. Once I re-mounted it, I had a couple of millimetres of clearance on either side.
    So, I'm quite pleased right now. This is a solid mount, and it looks pretty classy. I'll be using wire rope, but I haven't yet decided whether to go with roller or Hawse fairlead. The roller should be able to handle the more extreme angles, and I think it will look good with a fairlead cover on. The Hawse would have a smaller profile and better approach angle. I'll be installing the winch next weekend.
    FYI, J66P's website is at: http://k4designs.webs.com
    QUESTIONS
    1. What should I torque the bolts to? They are labelled '8.'
    2. The coating is thick and heavy duty. I'm wondering whether I should scrape this away where the washers for the bolts come in contact—to make sure there is metal to metal contact? Maybe even scrape the entire surface area of the rails that are in compression against the chassis? Would that make any difference?
    3. Is there such a thing as a Hawse fairlead cover?
    4. I remember seeing a roller fairlead cover that had a harness on the inside for the winch hook. As one pulled in the winch rope, the cover would securely lock into place. It had a handle on the outside. Does anyone know where to get one of these? I thought I saw it on an 80 series.
    BlueRock
    2001 LC90 D-4D, just lifted, and now with winch mount
    2001 LC 90 D-4D (Colorado GX) w/rear locking diff
    - 3" lift: OME 882/892X (55/70 mm) + 32" BFG AT KO's
    - Winch: Warn Tabor 9k; hidden mount (K-4 Design)
    - Diff drop; diff breathers; dual Optima batteries (YT D31A)
    Sweet!
    Hey AJ check this out - your next mod - come on you know you want to do this and ditch the bar
      Glad you was pleased with it matey, many thanks for the praise
      Another happy customer
      Colorado 3.4 V6, 4 inch Lift, 265 75 16 Cooper STT's, Custom Rocksliders, 30mm Wheel Spacers
        I am going to steal this idea and make one tnx 4 this
        I will post all the pics when done Phil
          Winch finally arrived, so I'll be installing it this weekend. Here's a preview...
          The Warn Tabor 9K fits in the mount just fine, with about 2 cm to spare, next to the motor.
          One thing I noticed is that the main mounting bolts, which I had tightened fairly hard with a normal half inch ratchet, were quite loose, after two weeks. The thick coating material on the mount slowly compresses, when under pressure. So, the mounting bolts will need to be re-tightened several times, perhaps over a few weeks. The torque value for that bolt type (M12x1.25, 8T) is 110 Nm. It's important to make sure this is tight, so that the mount is held on by friction.
          BTW, here is what I used to hold it up, while putting in the bolts...
          BlueRock
            It's done!
            More to follow...
            BlueRock
              Finally, here is the write-up on the remaining bits...
              1. The coating material on the winch mount compresses under load. It is therefore necessary to re-torque the bolts several times, after installation. I figure it's better to do this than scrape away the material. This is relatively easy to do, although it's a bit trickier for the fairlead bolts, as you can't get a torque wrench into there, once everything's mounted.
              2. The coating material also shrinks the sizes of the various mounting holes. This is very easy to fix with a drill. No drilling into metal necessary (except a tiny bit for the fairlead holes, as the bolts that came with my winch were a tad thicker).
              3. The installation of the solenoid box was a bit challenging. I figured the best location would be behind the grill, as that way I wouldn't have to take up valuable space in the engine bay and run four cables instead of two. However, this necessitated creating some custom brackets. I made this out of some aluminium 'L-beam' I found in the local hardware / DIY store...
              And, here it is with the solenoid box mounted. I rotated the box cover by 180 degrees and drilled more holes in the back. Electrical tape was used to prevent contact between the aluminium and steel surfaces.
              The solenoid box connector can be reached using one hand through the top of the grill opening
              4. The interior mini-bumper had to be cut off, in order to allow easy access to the winch clutch lever. It's relatively useless anyway, as the winch mount is effectively a solid bumper now. (I think it would be possible to do this without cutting it, if some additional main bumper trimming was done, or depending on the design of the clutch lever.) The end pieces had to remain, in order to mount the bottom of the rubber bumper...
                5. This is how I ran the cables...
                6. There were a couple of places I had to use a grinder to do a little bit of trimming. Also, I had to drill out one of the bolts I managed to snap.
                7. Finally, I installed a pair of Optimal Yellow Top batteries (the heavy duty models). It's probably overkill, but part of the motivation was to add a bit more weight to the front. I currently have them hooked up in parallel.
                The battery mounting brackets have been slightly modified to accommodate the increased height (about 2 cm). I used a threaded rod, which I bent at the end, to extend the back end. And, I added a metal plate to distribute the force over a wider area on top. This should be just as strong as the original mounting, provided the cold-bending of the rod has not weakened it too much. Washers were used to raise the front mounting point. This is the battery to which I attached the winch cables...
                Here is what the approach angle looks like, with the roller fairlead installed...
                  And, here she is, in the sunshine...
                  Once I stretch out the winch cable (and deform the loop at the end), I figure I can also install a winch cover. It doesn't fit, right now, as the hook doesn't bend all the way back.
                  How much does this all weigh? About 65 kg:
                  + 20 kg hidden winch mount
                  + 31 kg winch / solenoid / fairlead
                  - 7 kg inner bumper tube + other bits removed
                  + 21 kg Optima batteries net: (27.5 kg – 17 kg) x 2
                  One thing I haven't decided, yet, is whether or not to disconnect the air bags. With the solid mounting to the frame, presumably the system could be set off with a lower speed collision.
                  BlueRock
                    I'd love to do this but I have an alloy bar. Can it still be done or do the bar mounts get in the way?
                      Very neat job!
                        is it similiar to this one
                          I think they all use the same mounting points, so yes, they would get in the way.
                            Now with the roller fairlead cover (spray painted black)...
                            The winch is barely noticeable.
                            In fact, if you didn't know what to look for, you probably wouldn't know it was there!
                            BlueRock
                              yep it uses the same hols but I think the mounting brackets go the opposite ways so in theory all thats needed is longer bolts
                              sex vidio
                              replica watches
                              parisbahis
                              holiganbet
