Sway Bar D-Bush
  • Sway Bar D-Bush
    Hi all,
    I'm looking at replacing my D bushes. Will probably do the link bushes aswell
    I'm struggling to be sure on the bar sway diameter, I wrapped some tape round and then cut and the tape read 26.7mm when divided by pi.
    Although looking online it's kinda looking like a 25mm from the little i can see.
    I'm thinking go 26mm..... cant be too far wrong then hey?
    Also where is a good place to pick these up? I see superpro do poly ones
    I think this is what im chasing:
    48815 BUSH, FRONT STABILIZER BAR, NO.1
    48815-35100
    The car is a 99 RZJ95R 2.7 petrol
    Thanks,
    In advance
    Hi MrGreenz,
    Welcome to the forum. Try amayama.com for OEM stuff or your local stealership. Recently I replaced mine with OEM and made a huge difference. I also replaced the links and the link bushings as well.
    Find out the OEM part numbers from japan-parts.eu so you know exactly what to order, so you do not have to measure the diameter
    For Superpro stuff, I used sparesbox.com.au. I replaced the steering mount bushings with Superpro.
    Good luck.
      Thanks for the Info Gihan, very usefull
      Completed the job with 26mm bushes, i believe it was stamped on the bar to confirm the diameter.
      Ended up using nolathane ones
        Wait a minute... people still have their swaybars on their car?
          There are 2 sizes of front sway bar on 90 series. 25 and 26mm from memory. I like to run 1mm larger ID than bar to prevent bush curl out
