See more
See less
Tyres rubbing on the chassis rail
  • Tyres rubbing on the chassis rail
    Hi guys after having my lift and 285s fitted Iíve noticed my front driver side tyre is rubbing on chassis rail, is there anyway to fix this as I canít adjust my steering lock? p.s I have me cert nxt week will this affect it
    u need lower offset wheels
      Yes check the offsets of your rims.
      On a separate matter, the installer might not have added a sway bar spacer, so check the spacing between your front sway bar and the spring base on the struts .
        Change offset on wheels. Or as a lot of others have done, cut the rail back slightly. (I presume you mean the body mount)
        Depending on state and profile of tyre (I suspect youve gone to a 70 series) They may be oversize now, Best to check your sizes vs legalities of your state. May render your insurance void in an accident..
          Hey guys thanks for the replyís, yea managed to get some off set wheels -20/22 and no more rubbing on the chassis rail, just on the inner guards now
