90 Series Prado, not been maintained
    Take pics so we can have a butchers.
      Worth a look.
      Brake rotors and pads are cheap.
      Probably just low oil in trans as has been said.
        Well I've had my look, I didn't get any pics . Battery had gone dead so I couldn't get it started but from what I saw, the engine oil was surprisingly clean (I did the oil change on my dads liberty which is done every 10,000, and the prides was cleaner) the auto box had oil in it, but without it running I couldn't check the actual level. The interior has been pretty much trashed, and the entire is filthy, but nothing that can't be fixed with some TLC. Basically everything I expected to be there was there, no reservoirs were empty. It seems like a good buy, and I'm going back over with a fresh battery to have another look in a few days with dad, who fancies himself a bit of a mechanic. Honestly I'm not sure what could be wrong, but if we can work out its nothing major like a piston ring or a cracked block, I think I will pick it up and race to fix it before rego is due at the end of January.
          Oh forgot to mention, I also found out it has been raised on some old man emu suspension, but that was some 10 years ago, not sure if it still has the potential is used to. And most likely I will be forced to replace the muffler due to rust
