You are probably sick of these questions, but I like the car and am worried that the model is not new enough to avoid the problem. I am buying it from a Toyota dealer and the salesperson says that if it is after 2012 then it won't have a problem. (I will check the maintenance history as well.)
If it is vulnerable to that problem, what model is safe?
Or is the probability of the failure low enough to ignore?
I am buying it so I can stop using my range rover sport in the high country - I therefore need it to be reliable.
Thanks for your help!
