Whilst doing some research on towing, I found some interesting information that could impact anyone towing more than 2500 kg with the new 150kW/500Nm Prado.
On page 193 of the current owners manual (Aug 2020 to current) Toyota have imposed a maximum GCM of 5490 kg for all models. A copy of that manual can be downloaded here:
https://toyotamanuals.com.au/documen...aug-20-current
Prior to Aug 2020, the maximum GCM limitation was 5990 kg for automatic and 5490 kg for manual. That manual is available for download here:
https://toyotamanuals.com.au/documen...-aug-19-aug-20
I understand that GCM isn't meant to apply to light vehicles, however if a manufacturer specifies a GCM limit then legally it becomes a sticky issue.
I have contacted Toyota and it's currently under investigation. My main question is why the GCM limit has reduced on a vehicle when it's more powerful and all other weight limits are the same?
In the meantime, if you tow a heavy trailer beware of the limitations and legal requirements.
