Wet carpet
  • Wet carpet
    Hi guys
    Has anyone had the prob of the carpet in the back area becoming wet. Haven't been off road for a while, and I have checked the seals but cant see where the water ingress is coming from. Is this a common prob as I have only had the car for a year. It is a 2006 VX prado
    Very novice dude
    Do you have a roofrack ? If so the leak could be through the bolt holes that go into the roof . Replace the rubber seals on the bolts and the gasket that goes under the mounting plates . Use sealant on all of the rubbers .
