Gear shift vibration
  • Gear shift vibration
    Hi all (apologize in advance for this 1st message without previous presentation or contributions...)
    I recently bought (new) a Prado, so it has the current 2.8l diesel engine and in my case, manual transmission.
    The only "issue" is related to the gear shift. It vibrates significantly, specially when idle and low gears
    I'd like some advice, should I consider it an important issue (or better forget about it)? Has someone gone to his dealer with the same problem? Does it have an easy solution or better "don't touch"?
    Thanks a lot!!
