Cheers, thanks for the info. Will get one on the way!
Yes another CarPlay question 2018 Kakadu
- 1 like
Just wondering if it will still be 5 weeks delivery post covid...
https://youtu.be/z8-DmSl-Myc
1. On the newer 150’s you pull out the ac panel. Just pulls out toward you.
2. The remove 4 x 10mm bolts and the whole stereo and ac vents above pull out towards you.
3. Then disconnect all leads and mount module as per youtube video above. You have to remove about 15 screws on stereo and insert a couple of ribbon cables. Then plug in supplied harness. It’s all plug and play.
- 1 like
Android Auto currently needs a cable although i believe they are working on a firmware update to change in the future. Carplay is wireless. get-shareit.com get-vidmateapk.comLast edited by ozcanroy; 25-03-2022, 06:15 PM.
- 1 like
does this unit work with the separate amp and rear screens in the Kakadu?
Regard: Test De Pureté
