Sub tank question
  • Sub tank question
    Hi first time owing a 2001 parado, and first time owing a car with a sub tank
    may sound like a silly question but how do I fill up and switch over to the sun tank?
    When you open the fuel filler, you’ll notice the pipe has two options, one for each tank.
    A really simple idea.
    Then on the dash you’ll have a sub tank gauge and switch. Press the switch and it will draw from the sub tank.
    Again, a very simple design.
    Only fault I found was when the low level light comes on, it stays on even when you switch tanks.
    Gets annoying so work out when to change over and you won’t see the light.
      Cool thank you very much
        A really simple idea. spider solitaire 2 suit
        Excellent answer
