thanks Justo your cheat worked like a charm now the boss can enter directions while I am driving :wink:
Toyota GPS SatNav
2004 Grande V6 4.0L, Sovereign bar,Tow Pack,Hard Spare Wheel Cover,Rear Spoiler,Reverse parking sensors,Headlight & Bonnet Protectors,Pacemaker Headers,Safari snorkel,Stebel Nautilus Compact Truck Horn, Vapour Sequential Gas Injection , IPF 900 xs,Dual Battery ,radiator protection plate,K&N Airfilter,King Springs,GME TX3440,Waeco CF-60AC Verb,Reverse camera
No probs mate, it's surprising what you can find on the good ol intermenet when you search around for an hour or 3.
:shock: 8)03 Grande V6 4.0L, ARB Deluxe winch bar, XD 9000 Warn winch, Pacemaker Headers, Colour Coded Safari Snorkel, K&N Airfilter, Slotted RDA rotors, 55W HID Hella Rallye 4000 spotlights, Dual batt, TJM comp, TJM underbelly bashplate and custom stainless front bashplates, Extended diff breathers, Reverse camera (Eclipse), Yokohama AT-S, ICON 2.5 adjustable remote resi coilovers(front) ICON 2.5 piggyback shocks(rear), 2" lift airbags, Icom ic400pro, Engel 40L, Custom drawer system, Stainless recovery points, Kimberley MyCube rooftop camper.
Re: Audio Input in '05 Toyota Sat Nav
Originally posted by mumstrukI would love to input audio into my '05 SatNav. I've done the camera install and seen the back of the unit. This must be an easy job but I am hoping someone may have already done the hard yards already. Any clues or links?03 Grande V6 4.0L, ARB Deluxe winch bar, XD 9000 Warn winch, Pacemaker Headers, Colour Coded Safari Snorkel, K&N Airfilter, Slotted RDA rotors, 55W HID Hella Rallye 4000 spotlights, Dual batt, TJM comp, TJM underbelly bashplate and custom stainless front bashplates, Extended diff breathers, Reverse camera (Eclipse), Yokohama AT-S, ICON 2.5 adjustable remote resi coilovers(front) ICON 2.5 piggyback shocks(rear), 2" lift airbags, Icom ic400pro, Engel 40L, Custom drawer system, Stainless recovery points, Kimberley MyCube rooftop camper.
Originally posted by mebbearHi Tim;
Yes i do,u need to go to...http://www.pinemountainfirearms.com/pmf/tundramods/
and build the module outlined in the webpage...then locate the speed sense wire from the toyota sat nav being pink/blue on a grey plug on back of sat nav unit....
cheers bundy
Just like everyone else I am sick of not being able to access some satnav menu's whilst moving. I have the 26028 satnav in a 2008 Grande and was wondering if anyone had tried the Tundra mod on this model satnav.
Secondly can anyone confirm the colour of the speed pulse wire. In the Tundra mod it is white, in the abve post bundy says it is pink/blue, but I don't have any wires of these colours running to a grey plug.
Based on the photo of the white wire from the Tundra mods location on the grey plug I am asuming my speed sensor wire is the purple/white one below.
I have also tried unpluging my GPS antenna and driving around and the satnav unit still senses I am moving and disables some of the menu items. I think it is safe to assume in my model that the speed pulse sensor controls access to these menus, not the GPS signal.
Last but not least, if I can establish which is the correct speed pulse wire is there any reason I need to go to all the effort of building the circuit in the Tundra mod or could I just cut the wire and put a simple on/off switch on it?
Would appreciate any advice.
MPFBlack 2008 Prado Grande (no mods yet)
Ok, I eventually got around to doing this mod on my Prado.
I'm in South Africa so the wiring colours and things my not be identical.
In any event, my Prado is a 2008 model and I was able to solve the mind-numbingly annoying problem that everyone complains about with the satnav not allowing user input while the vehicle is in motion.
Here's a photo of the rear of my satnav unit and another of the connector:
The only thing I needed to do was to fit a switch in line with the speed pulse wire.
When the switch is open the satnav gets no pulses and things the vehicle is sationary. When the switch is clsoed it all works as usual.
There are a couple of side effects to this.
When the switch is open, you can do whatever you like on the unit in the way of entering addresses etc but the unit will not be keeping track of your location while in this mode, so, when you're done, you have to close the switch again and wait two or three seconds for the unit to update and then the displayed map will suddenly jump to the correct position.
To me this is a non-issue. The usefulness of being able to enter data while on the move far outweighs the very minor issue of having to wait a couple of seconds for the map to update when done.
If you have a CD with MP3 files on it, then this mod allows you to browse your music collection, read file names etc while on the move too.
Suddenly my satnav unit isn't quite the white elephant I always thought it was. It is actually usable now.
Tim
For those that may be interested I installed a simple on/off switch on the speed pulse wire (the purple/white one in my 2008 Grande - see previous post).
When the switch is in the off position it gives me full access to all the menu option. There is a bit of a catch . . . . after about a minute or so the GPS must kick in and the satnav unit realises that you are moving and locks you out of some of the menu options again. This is not a great problem as it gives you plenty of time to type in an address or access the phone keypad.
Obviously this is why the guy who did the Tundra mod made himself a circuit to trick the satnav into thinking it is doing 5km/h. I am now going to make this circuit and install it as his instruction on the website are really simple. I don't think I really need it but it looks like a bit of fun.
For the time being the simple on/off switch is going to make my life a lot easier.
Re: Toyota GPS SatNav
Hi Guys,
I recently had a failure with my GPS head unit which it wasn't able to display any maps. To my surprise it turned out to be a disc failure and Toyota kindly replaced this with a Version 14 disc - previous was Version 12.
The only problem now is that the overwrite function that previously worked now does not ie Menu, Volume, top right, bottom right, top right, bottom right, override.
Does anyone have any clues as to whether the disc could impact on this overwrite feature and whether there is another way back in?
My Prado is a 2006 model
Hopefully someone knows - spoke to Toyota but they wouldn't tell me how to get into it - liability and all that crap
Cheers Pappy
Pappy,
I had the same issue when I upgraded my 2006 Grande GPS headunit to Whereis v14. I lost the ability to 'override' the gps unit. It took a few minutes to load the new disk (v14) when I put it in, almost like it was updating the firmware or something. Losing this override ability greatly annoyed the wife.
Hopefully this will be corrected (or atleast an override 'feature' put back in) in v15. Whereis v15 is due out this year (2009) http://poweredby.whereis.com/shop/It...=21&PageID=376.
Its all about the WAF. :mrgreen:[size=7][b]Black 2006 3.0TD Grande[/b] - Reverse parking sensors, Reverse camera, Thule Aero Crossbars (x2), Headlight Protectors, Bonnet Protector, Front Weather Guards, Tinted Windows, Towbar, Whereis v14[/size]
Hi there, this my first post. I have a 2006 Grande which was purchased 4 months ago. The only thing I don't love about it is that the GPS only seems to work for a few hours in the morning. After that the GPS mark goes off and slowly the GPS looses its way. Around town this does not seem to matter but in the country which is when I need it most, it plays up and becomes useless. Can any one help me here. Romano
Sorry if this is a dumb question but I don't know where the DVD player is for the Toyota GPS.
I have a 2003 Prado the one that has no model number on the headunit face. It has a slot for CD and Tape behind the screen and a 6 stack player under the front passenger seat (don't know why it was put there and not in the space in theglove box :? )
Anyway if someone can advise me where to look as I want to upgrade the disc.
A friend has a BMW X5 and his DVD is located in the rear cargo area next to the 6 disc stacker.
Rolf
