Rig Build 120 D4D Grande - 'MLC'
  • #76
    Originally posted by ondaboat View Post
    Howdy MLC,
    Just wondering did you put the Cooper 265 70 17's on B4 the lift kit ?
    Regards Adam
    I did ondaboat, got some rubbing on the inner guard at full lock only, otherwise all ok.
    • #77
      Ugrade to a 3 inch exhaust - yep what a good idea.
      Do it myself with some help from mates - yep great idea.
      Re-assessment of above thoughts.... WHAT THE F%^& WAS I THINKING.
      I will leave the thread update of my exhaust to Matty to post considering he has spent 2 days dealing with 3 x MOTHER (BEEEEEP)(BEEEEEEEP) BOLTS that connect a short arsed dump pipe to a turbo that is 18 months old.
      No wonder 3 inch exhausts give you increased power. Its a refund of the effort and energy expended in getting the (BEEEEEEPING) thing on!!!!!!
      Sincerely peeved and ready to buy a motor bike.
      MLC
      • #78
        Hey Rob, did you get those LED lights for the interior yet? My finger is itching on the 'buy it now' button
        • #79
          MLC
          Excellent plan
          Get yourself one of these
          You wont regret it!
          1coolbanana
          • #80
            Are they rocket launchers I see on the rear?????
            • #81
              Guess what, I've finished fitting the Manta 3" stainless exhaust for you mate!!! You owe me mate!!! That and the relocation of the BRC diff breather block last night... Not a bad effort!
              Matty80
              • #82
                I wish it was!
                • #83
                  Ok so I now have a 3 inch Mandrel bent Manta exhaust system.
                  Like most on this forum that have done their own install, 99% of the install was straight forward. The mantra system includes the dump pipe which means undoing 3 little nuts that hold the original small dump pipe onto the turbine. So easy, we (Matt) set about undoing those 3 little nuts..... and that's where the proverbial ht the fan. These nuts which are the pinch type at one end are made of mild steel that rounds off like putty. Add to this the impossible location of one of the nuts and you have the perfect recipe for disaster. Seriously Yota must install this bit of pipe with the motor BEFORE they lower it into the engine bay. Crappy design....
                  In the end after numerous attempts with numerous spanners, sockets, extension bars, multi grips, 2 cans of WD40 a heat gun, a flame torch and a lot of chosen words the last of the nuts wold not release so Matt applied all the above to the stud. After much persistence the stud came out, the dump was off and the new system went in effortlessly.
                  The end result is the note is a minor change and the turbo is clearly audible, importantly though the rig is now ready for the Chip-It chip which will go in soon.
                  Thanks to Matt and Dave for their efforts, especially Matt for his tenacity in not giving in and applying a repetitive regime to ensure the stud did not snap off in the turbo!
                  MLC
                  Matty80
                  • #84
                    I forgot to take before and after pics but yes they look fantastic!
                    • #85
                      Sweet looking pipework! Where's the flexi joint in the new pipe?
                      • #86
                        No flex joint in the new system, had me stumpedd for a bit - but i guess thats the way its supposed to be?
                        • #87
                          EGT installed today. Keep an eye on those exhaust temps!
                          MidLifeCrisis
                          Out of control poster!
                          • #88
                            Some pics of the 3 inch Manta system:
                            MidLifeCrisis
                            • #89
                              EGT probe in the dump and close to the turbo. It is the shiny bit coming off the right hand side of the pipe:
                              MidLifeCrisis
                              • #90
                                One word.... Awesome! Well done fellas. Dyno results soon?
