Originally posted by MidLifeCrisis
View Post
Rig Build 120 D4D Grande - 'MLC'
Ignoring the comments (true of course) above, I installed a low coolant alarm with Matt as an assistant last week.
I will second that MLC, like Try said, where did ya get it and how much ?[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][CENTER][SIZE=2]
[/SIZE][/CENTER]
Wooley, I suspect it will fit easily to a 150. Just cannot remember the setup of your overflow bottle.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
Picked up a Toyota branded Rhino rack 1500cm for the princely sum if $100. Thanks ants for the information
. Will look at a separate set of the cross bars so I can mount on and off as a unit. Anyone selling the longer bars??
Someone should blow up auto-correct on i-phones. I meant AMTS, aka Andrew, aka The Prado Official Offmarket Fitment Engineer (DO NOT ATTEMPT TO ABBREVIATE THE NAME)Originally posted by Matty & Loz View PostWho is 'ants' MLC? Are you having another one of those senile moments now that you are a whole year older?
PS There is a milford cargo barrier for $100 if anyone is interested. Needs top brackets otherwise in great nick!
Last edited by MidLifeCrisis; 18-03-2012, 01:37 PM.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
No worries Rob, but can you think of a better position description that doesn't spell POOFE ?!Originally posted by MidLifeCrisis View PostSomeone should blow up auto-correct on i-phones. I eant AMTS, aka Andrew, aka The Prado Official Offmarket Fitment Engineer (DO NOT ATTEMPT TO ABBREVIATE THE NAME)
You're right about that. M.A.T.E.S. garage has a nicer, heartwarming feel about itOriginally posted by amts View PostNo worries Rob, but can you think of a better position description that doesn't spell POOFE ?!
Well thanks to amts I picked up a 1500 x 1010 mm Rhino rack for $100 (internal dimensions). Bought a set of 1350 black Rhino cross bars (longer than my Toyo ones) and assembled it. Just need the rod holder and Ostrich Wing or Hannabel annex and that's the roof done. Also renewd the Action 4x4 subscription to get the rack bag. Will take pics soon.
Other to do's in the next 4 weeks are twin wheel carrier to be fitted!Last edited by MidLifeCrisis; 22-03-2012, 08:38 AM.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
Nice work Rob - has anyone got dibs on your toyo cross bars???
Seeing as though you have got your hands on a cheap rack (no I dont mean Lea) i was thinking you might be feeling a little generous...Cheers
Micheal.
Matty80
