Rig Build 120 D4D Grande - 'MLC'
    Thanks Piecrust. And to think SWMBO says I need to trade it in on a 6 inch lifted 100 series or a Pootrol......
    Only problem with that 6 inch lift MLC, is that you've been telling Lea that 2 inches is 6 inches for the last 4 years...
    • Ignoring the comments (true of course) above, I installed a low coolant alarm with Matt as an assistant last week.
      • Hi MLC
        Can you please give us any more details on the coolant alarm.
        Looks neat.
        Cheers Troy
        • I will second that MLC, like Try said, where did ya get it and how much ?
          [CENTER][B][U]Matt
          [/CENTER]
          [SIZE=2]
          [/SIZE][CENTER][SIZE=2]
          [/SIZE][/CENTER]
          • Ok gents, It comes from here.
            They normally charge $190.00 but if you mention Mid Life Crisis and Prado Point you get it for $160. See post number 45 here
            Regards
            mlc
            • I've been meaning to call an find out if they have a kit for the 150. Looks good, mlc.
              2011 150series GXL
              • Wooley, I suspect it will fit easily to a 150. Just cannot remember the setup of your overflow bottle.
                  There's no little blanking plugs, screws, caps for it to fit.
                  2011 150series GXL
                  • Picked up a Toyota branded Rhino rack 1500cm for the princely sum if $100. Thanks ants for the information . Will look at a separate set of the cross bars so I can mount on and off as a unit. Anyone selling the longer bars??
                      Who is 'ants' MLC? Are you having another one of those senile moments now that you are a whole year older?
                      • Originally posted by Matty & Loz View Post
                        Someone should blow up auto-correct on i-phones. I meant AMTS, aka Andrew, aka The Prado Official Offmarket Fitment Engineer (DO NOT ATTEMPT TO ABBREVIATE THE NAME) PS There is a milford cargo barrier for $100 if anyone is interested. Needs top brackets otherwise in great nick!
                        MidLifeCrisis
                        Out of control poster!
                          Someone should blow up auto-correct on i-phones. I eant AMTS, aka Andrew, aka The Prado Official Offmarket Fitment Engineer (DO NOT ATTEMPT TO ABBREVIATE THE NAME) PS There is a milford cargo barrier for $100 if anyone is interested. Needs top brackets otherwise in great nick!
                          No worries Rob, but can you think of a better position description that doesn't spell POOFE ?!
                            You're right about that. M.A.T.E.S. garage has a nicer, heartwarming feel about it
                            • Well thanks to amts I picked up a 1500 x 1010 mm Rhino rack for $100 (internal dimensions). Bought a set of 1350 black Rhino cross bars (longer than my Toyo ones) and assembled it. Just need the rod holder and Ostrich Wing or Hannabel annex and that's the roof done. Also renewd the Action 4x4 subscription to get the rack bag. Will take pics soon.
                              Other to do's in the next 4 weeks are twin wheel carrier to be fitted!
                              MidLifeCrisis
                              • Nice work Rob - has anyone got dibs on your toyo cross bars???
                                Seeing as though you have got your hands on a cheap rack (no I dont mean Lea) i was thinking you might be feeling a little generous...
                                Micheal.
