Matt's 150 GXL
  • Impressed. 712km home and 10.9 on the in dash. Truthfully it will be 11.4/100km. Still real impressed !
    Not bad towing a tonne !
    matt150
    [CENTER][B][U]Matt
    [/CENTER]
    [SIZE=2]
    [/SIZE][CENTER][SIZE=2]
    [/SIZE][/CENTER]
    • Thats good economy Matt considering the weight and aerodynamics you are pushing.
      Great build to.
      • UPDATE: The SB is a good thing. I reckon exhaust is helping also. Actually, the car is going great and I am very happy. I plan to get it on the dyno at Deisel Care in Tammworth. Damo has advised me to get it dyno tuned and fine tuned correctly. So far I have just tuned it to setting four (I think) and it pulls well. The fuel economy seems to be not really effected, next tank will tell the story better.
        [CENTER][B][U]Matt
        [/CENTER]
        [SIZE=2]
        [/SIZE][/CENTER]
        • Im currently getting 11.2L/100km, no camper. Are you turning it off going down hills Matt?
          • Originally posted by adamr7 View Post
            Adam your tyres would be good for 1-1.5 lts per 100 reckon.
            [b]Rob[/b]
            • I reckon you are right Rob.
              • Na, no roofrack yet. That will eat a litre extra per hundred km, easy as..
                [CENTER][B][U]Matt
                [/CENTER]
                [SIZE=2]
                [/SIZE][/CENTER]
                • Been busy, sick of the friggin rattles from the back seat/cargo area. Have removed the rear seats and need to build a floor now and re-fit the cage..
                  But, no noises now and about a 40 odd kg weight reduction....
                  [CENTER][B][U]Matt
                  [/CENTER]
                  [SIZE=2]
                  [/SIZE][/CENTER]
                  • My adjustable sway bar links showed up today. They look pretty good. Superior Engineering don't even charge freight for any purchase over $100. My links were $205. I will fit them on Saturday Arvo.
                    matt150
                    [CENTER][B][U]Matt
                    [/CENTER]
                    [SIZE=2]
                    [/SIZE][/CENTER]
                    • Cant wait for the report. This just may be my next mod too.
                      • Matt what have you done to want the adjustable sway bar links? My lift ended up around 60mm and I haven't had any issues.
                        Richo.
                        Sent from Richos iPhone using Tapatalk
                        • Just want to correct my rear sway bar angle back to the factory angle.
                          I have read up on this subject in the 120 area, and understand the discussion with regards to rear wheel travel and shock absorber limits etc. I am happy with my purchase and will see if my Prado Handles better with the links installed and the angle corrected.
                          matt150
                          [CENTER][B][U]Matt
                          [/CENTER]
                          [SIZE=2]
                          [/SIZE][/CENTER]
                          • Let us know if they're noisy.
                            • Originally posted by D4D View Post
                              I shall D4D, they should be ok, they have a grease nipple and I think they will be pretty quite once greased.
                              [CENTER][B][U]Matt
                              [/CENTER]
                              [SIZE=2]
                              [/SIZE][/CENTER]
                              • Fitted up the adjustable links today. Handling seems a lot tighter, very happy..
                                Before -
                                After -
                                matt150
                                [CENTER][B][U]Matt
                                [/CENTER]
                                [SIZE=2]
                                [/SIZE][/CENTER]
