JimmyC's 2010 150 GXL build
    JimmyC
  • JimmyC
    replied
    Installed my Ultragauge yesterday. Mounted to the top of the steering wheel with double sided tape (at the moment). Looks pretty good. The photo doesn't help much but I only have to lean forward a little to see the odometer.
    https://s22.postimg.org/fqeg6f9wh/Ultragauge.jpg
    Leave a comment:
  • Hollywood
  • Hollywood
    replied
    I was leaning on my bullbar chewing the fat with my neighbour and looked down and noticed the wiring had been rubbing. Managed to get a Dremel tool onto the edge of the guard and take a small section out before it did any real damage.
    Leave a comment:
  • Carni
    replied
    Originally posted by JimmyC View Post
    Yesterday I got around to installing LED bullbar indicators and parkers after getting sick of blowing bulbs. Upon investigation I found the back of the wires on the ARB bulb type ones had rubbed though and were exposed. Picked up new ones from my local ARB, $109 for the pair. I know you can get cheaper but the 'can't be bothered waiting' factor was high!
    Originally posted by Hollywood View Post
    Did they rub through on the cutoff section of bumper? That's where mine were rubbing but I got it before it went too far.
    Exact same thing happened to me. But they were rubbed through on the drivers section by the time I noticed
    Leave a comment:
  • JimmyC
  • JimmyC
    replied
    Yeah that's where mine did it! If the lights were in good condition i would have taken a little notch out of the bumper to compensate but decided against it.
    Leave a comment:
  • Hollywood
  • Hollywood
    replied
    Leave a comment:
  • JimmyC
  • JimmyC
    replied
    So my Utragauge arrived today, Looking forward to installation!
    https://s10.postimg.org/6nhc8dapl/14...85972735_o.jpg
    https://s10.postimg.org/r8w409sah/14...50652266_o.jpg
    https://s10.postimg.org/o3bia29o9/14...22698273_o.jpg
    I also got around to changing the ugly big industrial push button override switch for my SBI12 to a nice new one. Looking proper flash now!
    https://s10.postimg.org/818z3o9yx/14...405833_o_1.jpg
    Leave a comment:
  • kenny5000
  • kenny5000
    replied
    Ordered an ultragauge from the US. Sent via USPS shipping which I've only read now on their website about how much they advise you not to use it! Fingers crossed it shows. Also ordered a replacement switch for my SBI12 override and a dual usb outlet blank.
    http://www.ebay.com.au/itm/291567165...%3AMEBIDX%3AIT
    http://www.ebay.com.au/itm/111889126...%3AMEBIDX%3AIT
    Slowly working through all the little problems with the car I have overlooked for the last 2 years. Small broken trim blips and alike. Big Job!
    I have had heaps things sent through USPS (some expensive) with no issues, I would be more worried about Austpost!! One item in particular that coincidently was ordered from the US and shipped by USPS was found on the road a few suburbs over by a thankfully honest person who hand delivered it to me.
    Leave a comment:
  • JimmyC
  • JimmyC
    replied
    Leave a comment:
  • JimmyC
  • JimmyC
    replied
    So the chief financial officer has let me at some of my tax return $$. Tossing up between a scangauge, ultragauge or projecta battery monitor. Any thoughts?
    Leave a comment:
  • JimmyC
  • JimmyC
    replied
    New driver's side CV boot, wheel bearing and hub replaced. Hopefully it's smooth sailing from here on out!
    Leave a comment:
  • JimmyC
  • JimmyC
    replied
    Replaced my aux fuel filter today and switched to a 5 micron. Also switched it from a pre to a post filter. Tip for others is before installing the fm100 for the first time make sure the fittings will move and undo. Mine were very very tight
    Leave a comment:
  • JimmyC
  • JimmyC
    replied
    Well I found out what the noise was... Luckily not the air-con compressor. The new serpentine belt installed had large lump on the flat side of it. Must have caused the noise somehow on the tensioner. Replaced belt and noise gone. Funnily the new-new alternator is making a squeaking noise when turned by hand too. Maybe it's just an OEX thing?
    Somehow have taken off some more of the plastic in the wheel arch yesterday. Not sure how it happened but time to start searching for a replacement!
    Leave a comment:
  • JimmyC
  • JimmyC
    replied
    Finally received the refund from Repco on the alternator. One less thing.
    However now it seems the air conditioner compressor has developed a noise. It makes a noise to what id describe if there was a ball bearing bouncing around inside it. Only does it when the engine is cold and when the engine warms it goes away to almost nothing. Aircon still works so this is a problem for future me to deal with.
    Looking at buying a used compressor for about $250 as a new one is $900 plus. Anyone have any tips for this?
    Leave a comment:
  • JimmyC
  • JimmyC
    replied
    Originally posted by brogers View Post
    You decided against a foxwing style awning in the end Jimmy...obviously...the ARB awning is a good one, but I'm about to fit out a new Prado shortly and am looking at a foxwing...as we found we wanted cover over the rear cargo area as well...any thoughts or comments about the foxwing style of awning...did you consider one?
    I had a good think about it but in the end it came down to the fact the fox wing awnings are huge on the car when folded up.Plus I couldn't justify 3x the cost for one. Maybe in the future.
    Originally posted by Limo Guy View Post
    Mine went at 162000, wasn't game to do it myself.
    Local Auto Spark supplied and fitted for $546 while I wandered around the local auto shops.
    I think the aftermarket are higher current output than OEM and one supplied to me volts up by 0.5 - 1.0 volts.
    $546 is very good for fitted. I was $601 post AANT discount at repco.
    Leave a comment:
  • Limo Guy
  • Limo Guy
    replied
    Leave a comment:
