Surface Pro 4 as Navigation tool
  • Surface Pro 4 as Navigation tool
    Hi,
    I have a new SurfacePro4 (from work), that I want to use it with OziExplorer for navigation. Looking into how best to attach it to the dash/floor/windscreen of my 120. I have looked into the RAM mounts, pretty expensive, but short of doing some custom job, which I cannot since I do not have a welding machine (I might get some soon and start learning how to weld, I might be handy), that might be the only option.
    Has anybody installed SurfacePro in their 120?
    Thank you
    Borec
    The surface pro 4 doesn't have inbuilt GPS - you'll need a GPS dongle.
    Its similar in weight to an Ipad 2 so any of those solutions should work. . A few people used to mount them from a suction mount and rest the bottom on the dash in front of the clock. I do remember seeing Velcro used somewhere.
    http://www.pradopoint.com/showthread...one-in-a-prado
    Or check out ClicOn. You need a mount + holder. http://www.holdmyphone.com.au/holder....html?cat=2765
    I have the centre mount for my iPhone 6, but not sure if it would take the weight of a surface.
    http://www.holdmyphone.com.au/mounts...html?mode=grid
    You could also get an Ram triple suction mount and clic on holder for example.
    Or get creative: http://www.pradopoint.com/showthread...illbilly-Style
      Something like this maybe?
      http://www.ebay.com.au/itm/Car-Floor...cAAOSwd4tUKSlw
      White 150 GX, TJM t13, TJM scrub bars steps, TJM underbelly protection, Kaymar rear bar, matt black speedy avalanches with mickey T ATZ' P3s, ARB BP 51 suspension, Heat exchange shower, Safari snorkel, on board air tank, custom rear drawers, wind cheeta rack, custom maxtrax mounts, in dash ozi explorer, cargo barrier and more!
        Got the dongle already
        I have looked through most of these, problem is that surface is somewhat larger and heavier, the RAM mount will work, but it is expensive (liek $300, if you put all the parts I would need together)
          iPad 2 is 600g, the Surface 4 is 730-780g depending on processor so its not that different. But those who had Ipad 2's usually suction cupped them to the windscreen but rested the bottom of the pad on the dash/console so the weight was supported.
          Surface Pro 3 is almost similar in size to the 4. So something like the Arkon would work. http://www.arkon.com.au/arkon/arkon-...tab-cm117.html
          How are you going to power the surface? I could never find a suitable car charger?
            Ya there is not one, will have to get inverter, thinking about putting in a roof console, and having the inverter there (as I expect getting water in the car in deep water crossings, so do not want it under the seat) and have cabling running into some part of a dashboard, so I can just plug it in, it is bit of a long term project.
            Those hold my phone brackets look good, I will try to find out if they will hold the surface properly and most importantly will not vibrate on corrugation.
              I have a Surface Pro 4 which I have used as a nav tool with OziExplorer and a Garmin dongle - it works very well (I have an inverter under the passenger seat) but I have the same problem as you. I have only used it resting on the passenger seat but am looking to install a bracket. I'm also with you in thinking that none that I have seen look as if they are going to withstand the bouncing around on sand tracks (my favourite). I'm thinking of having one made for a 120.
              I can't understand why every manufacturer that I have seen want to have the computer rigidly sitting on an arm - what I need is some joints like you find in a steadicam so the mount can smoothly absorb most of the vibrations while holding the laptop fairly steady.
              skeliher
                I used a RAM laptop mount for my tablet for many years - the RAM Pod 3. Will easily survive all the tracks.
                [size=2][b]Prado 120 - 2004 GXL V6[/size][/b]
                [size=1]ARB deluxe bar, OME 2" lift, Safari snorkel, BFG A/T's, Ironman winch, LED bar, Redarc DC-DC dual battery, Rhino Rack Pioneer tray, Outback drawers and plenty of goodies inside. [/size]
                  I am tempted to buy this, but I reckon it will not be stable enough
                  http://www.arkon.com.au/arkon/arkon-...t-tab-fsm.html
                    That looks good too,
                    also this
                    https://www.rammount.com/part/RAM-316-HD-202U
                    with
                    https://www.rammount.com/part/RAM-HOL-UN11U
                    But looking at over $300
